Old 08-02-2008, 03:12 PM   #18 (permalink)
taco
Johnny 5 - '81 Honda Cm400e
90 day: 42.86 mpg (US)
Da bike - '06 Honda Shadow Vlx deluxe
90 day: 59.47 mpg (US)
mine is 4x4 so i have the 3rz, 2.7liter.
which 2.4l u talking about the 2rz or the 22re/22r?
cause my 3rz is just a longer stroked 2rz, with a bore is 95 mm and stroke is 95 mm, compared to the 2rz bore is 95 mm and stroke is 86 mm, the 3rz also have counter balances in the motor to make it smoother and about 8 whole hp more and 17 ft/lbs, but the curve comes earlier.
the fan thing may all be in my head but i will drive it with the block for a few more tanks then trry it off for a few to see if it really made a difference.
i just though the clutch fan might cause more drag than good., maye i should buy a billit one loose some weight and the clutch .
