The Tesla/Ford Fusion throttle has the same 'sanity check'.
Moderating the application of torque prevents damage from shock loads on the drivetrain, according to Jack Rickard. Electric torque in milliseconds instead of the microseconds with a gas engine.
The throttle dual signals make a hard-wired solution for regen .. with the brake signal adjusting throttle signal below a certain threshold .. a bit more CHALLENGING shall we say.
The torque signal from the throttle applied to the motor can, IMHO, have a simple ramp rate applied to limit transmission-destroying step-changes of torque. I have not gotten to testing that as yet. I'm still trying to 'test' the hardware over-current ... or get over 450 amps AC through the controller. I expect that checking how fast the torque changes would be a GREAT test .. if I could figure out how to measure the output torque directly.
I'd settle for indirectly as well. The slope of the current on the DC motor maybe?
Ideas anyone?
