Old 12-31-2015, 02:34 AM   #17 (permalink)
oil pan 4
The best thing I can think of to control the power steering is put it on a manual momentary switch wired to a time delay off relay that gives me between I am thinking 10 and 20 seconds of power steering per push of the switch.
Then place the switch on the center console so I can hold it down continuously if needed.
Driving the 3/4 ton suburban with power steering disconnected I have found that I don't need it most of the time. Backing up the trailer I will most certainly need it.
I believe the duty cycle of the hydraulic power unit is 2 to 3 minutes on, 8 to 10 minutes off. Depending on the load, temperature, ect.
