Old 01-01-2016, 05:05 PM   #16 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
If it were my car and I shared it with a partner who seems trepidatious about conspicuous mods, I do the grill block as stealthy as possible. So only do behind the grill blocking. Also, as far as upper/lower, I'd want maybe a 70% block total and the remainder to be in frint of the cooling radiator (not the AC radiator) if possible. Experiment. Maybe leave the top grill alone because it looks pretty small and might only be about 30% of total grill opening. If so, try blocking all of the lower grill. Monitor coolant temperatures if you can (another reason to get an ultragauge is precise readings from all engine sensors including coolant and intake temps).
An added plus of an ultragauge... it reads engine trouble codes. It is *almost* as robust as those handheld diagnstic tools mechanics have.
