Old 01-02-2016, 02:46 PM   #65 (permalink)
101Volts
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
I didn't update the photo, but the duct tape wheel arch covers (partial on front and near full on rear) made an improvement on the highway; with them I don't need to hold the accelerator down as much to stay at 55 MPH. Also, there's no problem with paint being removed from the car's finish; the tape is on the plastic wheel arch covers.
The block heater may not get it to operating temperature, but it does make an improvement; twice now I had it plugged in for 5 hrs. before starting, outside temperature 27/28 Farenheit and it got the coolant to 75-77 before starting. With RLI 5w40 oil the engine doesn't puff excessive smoke out of the tailpipe at startup this way nor does the engine rumble, it's a much smoother startup.
The Following User Says Thank You to 101Volts For This Useful Post:
deejaaa (01-03-2016)
