Old 01-05-2016, 06:28 PM   #1 (permalink)
botsapper
PSmodder lurker
NASA's aero technology to save aviation industry billions
NASA's Environmentally Responsible Aviation (ERA) project is pioneering new green technologies for the aviation industry. Technologies to reduce fuel consumption, aircraft noise and low-carbon aircraft.
Technologies include; new composite material fabrication, engine efficiency improvements, special outer coatings to reduce weight and air drag from insect strikes/splatter, weight reduction by recommending shorter tail fins with embedded air nozzles for better control, morphing wing shapes with multiple sealing flaps to close all flap/body gaps (reduces noise and efficient surfaces) and new hybrid wing body shapes.
NASA Wraps Up First Green Aviation Tests | NASA
NASA Successfully Tests Shape-Changing Wing for Next Gen Aviation | NASA
Glow with the Flow | NASA
Aeronautics | NASA
The Following 5 Users Say Thank You to botsapper For This Useful Post:
aerohead (01-06-2016), BamZipPow (01-05-2016), niky (01-06-2016), rumdog (01-08-2016), Xist (01-11-2016)
