Old 01-09-2016, 01:54 PM   #231 (permalink)
aerohead
how
Originally Posted by orengomotors View Post
Ok, how can i do the radius? with a tube 40m radius and a hammer? any other ideas?
Thank you
A sheetmetal fabricator would have a slip-roller which they'd use to roll the radius into sheetmetal.
Short of that,you might find pre-fabricated flue pipe for a gas-fired water heater of appropriate diameter,which could be cut down to create the soft edges.
The inside surface of PVC pipe can also be used as a mold to layup fiberglass radius sections.I did this for a trailer body."joggles" can be cast into mating edges of the part by taping chipboard strips inside the mold with aluminum tape.
Three coats of carnauba wax will get a clean release from the mold.
orengomotors (01-10-2016)
