Old 01-09-2016, 08:38 PM   #17 (permalink)
oil pan 4
The AC clutch pulley won't over drive the alternator to the desired speed at idle. It would only overdrive the alt by between 1:1 and 1:2, I need the full 1:3 overdrive. I have the billet specialties drivers side low alt mount and I am going to replace the tensioning bolt with a liner actuator
I need the alt for winter driving so the alt on off will be manual with easy belt removal, then fully automatic later.
