Originally Posted by Grant-53
See the recumbent.com site for the HPV design software by Wayne Shook. Some of the most efficient shell designs come from Delft University.
If you can get steel piano wire it may be less expensive than welding rod to use as a stiffener for the coroplast. Check their website for the latest sizes and products including hex core panels.
Are you referring this?
The Recumbent Bicycle and Human Powered Vehicle Information Center
It says: "Once the fairing is created ribs can be exported and printed to allow an easy creation of the actual shell using the strips over ribs technique."
Maybe the ribs could be exported to .dxf and i could cut it with the laser cutter. It would be great to finish the bodywork!
