Originally Posted by MetroMPG
Good question. I'll be interested in seeing the images you had in mind -- you could email them to me if you don't want to wait 10 days. darin@ecomodder.com
Initially, my plan is to just stick the tail on the Prius as-is (with any gaps filled in as required). I'll do a couple of runs to get some initial numbers and go from there.
But based on the effectiveness claimed for the other Gen 2 Prius tail we know about, I predict it will work better than it did on the Civic.
here's a second try,from Morelli's paper.Notice all soft perimeter radii
![](http://i1271.photobucket.com/albums/jj622/aerohead2/Untitled12_20.jpg)
Here,Morelli has added a Kamm extension which modifies the angular greenhouse
![](http://i1271.photobucket.com/albums/jj622/aerohead2/Untitled7_22.jpg)
upper edge into a softer radius,essential,he says,to get the 'fluid tail' to work.
This 2010 Kia Ray PHEV concept has the proper shape
![](http://i1271.photobucket.com/albums/jj622/aerohead2/Untitled1_33.jpg)
