Old 01-16-2016, 10:29 PM   #2539 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Update for Jan 16
I gave up on editing the video for the AC Controller testing I did for Dec 21. As you had all suggested. The log files are attached with a spreadsheet that I used to enter the DC Volts and amps that I read on the audio as well as the approximate rpm that I read them at. I then matched up the DC volts and Amps on the high voltage pack from the separate video. The video from the DC motor amps and volts did not work out. The audio from my headset did not work out. So this is what I was able to salvage.
