Old 01-16-2016, 10:33 PM   #2541 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Plans for the next test
So I think that the next test needs to be a bit slower at the beginning:
- get the audio verified
- get the videos running
- log the temperatures on audio, leave the thermometer by the controller, turned on
- start the AC logging
- start up the AC controller
- use the throttle to start up the AC motor (so I verify that the controller is taking current)
- *EDIT* check the AC output voltage with a meter as a check for the logging
- start up the DC motor, get up over 3600 rpm
- adjust the throttle to take less and less current until we it is in regen and showing the battery pack higher than it was at the start.
- log the heat spreader temp
That's the slow part, now for the fast part
- increase the load very quickly with the throttle until the controller reaches 300 AC amps
- Increase quickly .. 300, 350, 400, ... monitor the controller temperature
- shut it down with the ESTOP when it reaches ... 100C? The max operating temp is 125C
Paul - if you can confirm the max temp for the IGBTs on your spec sheet please? I found a Powerex 600V 600A spec sheet, but it may not be identical. 125C operating, 150C max
That should be about it!
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (01-17-2016)
