Old 01-17-2016, 01:00 PM   #7 (permalink)
darcane
darcane's Avatar
Originally Posted by Baltothewolf View Post
You are seriously damaging your engine. It's because when you go into vtec and it starts pumping oil (and suppose to have more oil pressure) the oil just foams and causes oil pressure to drop, who has triggers the code and disables vtec until the code is cleared. I have seen this code go ignored on a couple insights and it results in dead engines.
I'm not quite sure what you are trying to say here.
Yes, running the engine low on oil is bad and not good for the engine. I don't recommend this at all.
The first symptom, even before it gets low enough to trip the low oil pressure light, is that it fails to operate the VTEC system. Are you suggesting that he ignore a possible low oil level issue and go straight to spending money on parts that may not need to be replaced?
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
