Old 01-17-2016, 01:08 PM   #8 (permalink)
darcane
darcane's Avatar
Balto, that seems like great advice, and I \thanked you.
Darcane, come on, man! Take care of your car! Thank you for sharing, though. I have some stuff to figure out, but I was low! I topped off, turned off the CEL, and let it idle a bit, before revving past 4,000. It is after midnight, so I did not want to rev too much, or just go cruising, so I will look into it further tomorrow, but Balto, I will check that stuff!
Thanks!
I'm working on it, but more stuff is breaking on it than I have time to fix. To fix the oil leak, I believe I need to pull the engine. Again.
Hopefully your issue is just the oil level. Keep an eye on it for further symptoms and keep that oil level up.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following User Says Thank You to darcane For This Useful Post:
Xist (01-18-2016)
