Old 01-21-2016, 01:51 AM   #13 (permalink)
oil pan 4
I have another application for this. I have decided to do inter compressor stage cooling on my twin turbo diesel. Right now the T76 discharges air directly into the HE351VE intake. I am going to stick a large 3.5 inch in/out air to water intercooler in place of the simple U shaped piping.
To keep hours off the pump and save power because these pumps draw up to 7 amps and can run all the time I am considering keeping the pump off when interstage air temperatures are below 100'F to 120'F, then once the temperature switch is made run the pump on low until some where between 6 to 9psi of manifold boost are obtained. Then above cruise boost (5 to 6PSI) I would like the pump to kick on full speed.
