I picked it up today for $1500. It “seems” like a good deal because other Geo’s in the LA/OC/SD area were selling for $2500-3000K.
Pros:
1) Looks like previous owner installed a new brake master cylinder
2) Looks like previous owner installed new distributor cap and spark plug wires
3) No rust on the “suspension arm forks”
4) No rust on the wheel wells
5) SGii shows I achieved 53mpg on the drive home, AND I WASN’T EVEN TRYING.
6) Engine “seems” to run okay, It shakes a lot, but from what im reading, the 3 cylinder is not “naturally smooth.”
7) No Grinds in the transmission.
8) Coolant was nice green color
9) Engine oil was fresh (so I cant tell if it was milky or not)
10) No crusty oil deposits on the oil filler cap (see #9).
11) Body seams look straight, no obvious signs of accidents
12) Title is "clean"
Cons:
1) Craigslist advertised 167K miles, but when I looked at it today, the ODO had 187K miles….might have been a typo.
2) Rust on the muffler only, but it could just be a cheap ass muffler
3) Chipping/fading clear coat (as expected)
4) “Dashboard Cancer”
5) Sagging headliner
6) Air vents “flaps” have disintegrated
7) Battery is dead, I had to jump start it to drive home. It’s “possible” the alternator is bad….(another FREE ecomod).
8) Crack on the windshield
Short Term Plans
1) Basic maintenance (seafoam treatment, oil change, transmission oil change, coolant flush, new spark plugs, new air filter)
2) Work out all of the “gremlins” (try to locate and remove all squeaks, squeals, and rattles)
3) Dynamat the interior to reduce NVH
4) Remove back seat
5) Replace steering wheel (it’s disintegrating)
6) Replace Windshield
Long Term Planned ecomods
1) Make a new SGII custom mount on the steering wheel column
2) Cover up the passenger side mirror hole with a “delete plate”
3) Driver side mirror delete
4) Kill Switch
5) Almost OEM Grill Blocks
6) Smooth Under belly tray
7) Rear Diffuser
8) Almost OEM Rear Wheel Skirts
9) Almost OEM Partial Kaamback
10) Deep Cycle Battery
The 1.0 liter, 3 cylinder darling of Ecomodder….
It even comes with a free ecomod
![](http://i101.photobucket.com/albums/m65/jedikn1te/Geo%20Metro/20160122_100028.jpg)
