Old 01-24-2016, 07:30 PM   #94 (permalink)
kimer6
Wow! Great progress. I like the Chevy freeze plug/oil gallery plug trick. Yes, that filter bolt holds the oil relief valve in nicely!
I need to know how you post full size pics as the attachment goodie only lets me do 135kb or smaller pics.
How can I give you my email address without letting the world (and ex WHYffe...she puts the WHY in wife) know?
I'm welding up a 40 gallon fuel tank base for a 7500 watt Onan diesel generator. It has a Yanmar 3 cylinder almost exactly like the Kubota. I was looking for more 6011 welding rod and stumbled across the front cover of a spare Kubota last night. I was jumping for joy knowing the pics would help you.
Thinking ahead...... No vacuum for power brakes. Do you know how hard it is to stop a Metro with no vacuum assist? I rigged the suction line of the Kubota fuel pump to the vacuum line to the brakes. It worked...somewhat.
I connected the fuel feed and return lines in my Metro using a tee fitting. The leg of the Tee got connected to the port on the Kubota injection pump. The tank fuel pump worked fine drinking diesel fuel.
