Originally Posted by kimer6
I connected the fuel feed and return lines in my Metro using a tee fitting. The leg of the Tee got connected to the port on the Kubota injection pump. The tank fuel pump worked fine drinking diesel fuel.
When I got my engine a few years ago it had a block off plate for the fuel pump. I couldn't help myself and I bought two on eBay - one with the priming lever and one without the priming lever. Right now I have the one with the priming lever installed and I was planning to use the mechanical pump in the Geo.
Block off Plate:
Spare mechanical fuel pump, no priming lever:
Installed pump, with priming lever:
