Old 01-28-2016, 07:57 PM   #3 (permalink)
oil pan 4
The power steering system only develops those high pressures when the steering wheel is turned. When driving straight the pump is allowed to full bypass, only developing a max of 100 to 200psi.
Even then it still takes around 1 hp to turn it.
Pressure reduction will make absolutely no difference in MPG.
I am one of the few people to study the at rest state of power consumption on a Saginaw type 1 pump, here:
http://ecomodder.com/forum/showthrea...ing-29002.html
That lead me to this, the only way to further reduce parasitic P/S losses is to remove the pump from the system, here:
http://ecomodder.com/forum/showthrea...ion-32895.html
