Old 01-29-2016, 12:25 PM   #51 (permalink)
EVmetro
Originally Posted by Stubby79 View Post
Speaking of which, I measured the space between the end of the trans case and the frame rail on my '95. It was 5". Which should give me just enough room to comfortably shift the trans over the 4.5" previously mentioned. Hopefully.
Its nice when you start enjoying a project...
Here is a pic of how small that gap is between the drivers side frame rail and the transmission after you skoochy everything over to the drivers side. You can leave the axle nuts off when you verify side to side position, so that you can slide the axles back and forth to feel the fitment before welding.
The Following User Says Thank You to EVmetro For This Useful Post:
Stubby79 (01-30-2016)
