Old 01-30-2016, 03:18 AM   #27 (permalink)
cyclopathic
I really do not think that the pyramids are a good example. Mountains are naturally occurring and generally do not fall down, either.
Pyramid inclination angle is 43.3 degree; same as sand in hourglass. They generally do not fall unless damaged by external forces or as in FB picture above taken apart for building material.
EDIT: rreading more on bent pyramid it appears the angle on it was changed during construction from original 54deg to 43 to prevent collapse
The Following User Says Thank You to cyclopathic For This Useful Post:
Xist (01-30-2016)
