02-05-2016, 03:29 PM
#25 (permalink)
Blocking excessive grille opening will have a bigger effect than closing up seams. I'm sure you know you need a way to monitor coolant temps to ensure you don't go too far for your typical driving loads.
Does your car have a "manual" shift mode?
I've often found that you can get an automatic to upshift SOONER using manual mode than the default automatic programming permits. That will help as well.
