Old 02-14-2016, 12:02 PM   #849 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by Old Mechanic View Post
Measuring only injector pulse width, in a system with a fuel pressure regulator that is typically vacuum controlled will not give you the required accuracy of the amount of fuel delivered.
I would beg to differ. I have found MPGuino to be a lot more accurate than either the OBDII-based scanners (to include ScanGauge II) or the on-board factory trip computers I have used. MPGuino measures fuel injector pulse widths directly.
