Old 02-15-2016, 08:08 AM   #841 (permalink)
OBDuino coder
Magister's Avatar
Titine - '13 Hyundai Sonata Hybrid
I think it is because the code was done with an old IDE, it does not work with 1.0+, you have to install a 0.xx version
2013 Hyundai Sonata Hybrid
Old 02-15-2016, 11:37 AM   #842 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
I was able to convert the code to use the newest IDE, but I am not at all sure it will work. Does anyone want to test it?
Old 02-15-2016, 01:46 PM   #843 (permalink)
@Magister
You are a genius my freind
I have unistall version 1.6.5 of IDE and installed an old 1.0.6 that I have found over the net and now it compiles and load everything without errors
Now I got to work on the interface for a kw1281 protocol. I have a few options there for level shifters mc33290, L9637 or individual opto-isolators.
Old 06-25-2017, 07:20 PM   #844 (permalink)
Hello.
I have a simple task to achieve, I guess, but I'm stuck. All I need to do is to read the Speed of the vehicle using data from the obd2 k-line pin, and then to send a command to blink the brake lights when a certain decrease in speed is detected (e.g. more than 2km/h/s). I can not initialize the k-line and I am not able to read anything on the serial monitor on arduino . The vehicle is an 2004 BMW E60, uses ISO_14230_fast but I guess this is not an issue.
So, all I need Is some help from someone to extract from the code only the part for init sequence for ISO_14230_fast and sone way to read the speed on the serial monitor.
Old 03-16-2018, 08:47 PM   #845 (permalink)
Hi , tank you for obduino project ,I am sorry my English not good , I want build mpguino by arduino uno +serial elm327 but I can't found sketch code for that , I found obduino32k and removed comment from define elm but code not compile ,if you have update code send for me pleas
obd2
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 04:58 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 04:57 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 10:04 PM
