Old 02-18-2016, 11:47 AM   #9 (permalink)
Fat Charlie
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Like Old Mechanic says, maybe it's time for maintenance instead of modification. A brand new OE-sized radiator will probably have more flow than one with 24 years of crud in it. Going new and oversized may be too much cooling.
I wouldn't worry about the fan draw, because you shouldn't need much fan. Weight hurts on starts and uphills and helps on the glide and the downhill, but a hole in the air dam catches air whether you need it at the time or not.
Transmission type Efficiency
