Old 02-20-2016, 09:46 AM   #9 (permalink)
Bradherr
Silver car - '14 Chevrolet Cruze Diesel
90 day: 50.53 mpg (US)
Red Cruze - '17 Chevrolet Cruze Diesel
90 day: 51.98 mpg (US)
Originally Posted by mcrews View Post
welcome!
also, increase the psi in the tires to 40+
Also, since you drive on th freeway a lot, consider increasing the diameter of the tires on your next purchase. it will reduce the rpm at cruising speeds and get better mpg.
When your ready to buy tires, give a shout and will get you more info.
I run my tires at the maximum sidewall pressure of 51 psi cold. On the interstate when warmed up the tires will creep up to 56 psi.
I like the idea of running taller tires, I will definitely be doing this mod when the time comes.
At interstate speeds of 71 mph the engine runs at 2000 rpm.
Sorry, new users are not permitted to post links in their signatures.
