Old 02-20-2016, 05:10 PM   #139 (permalink)
planejob
BeginnerModder
A quick search shows an electric vacuum pump for 1999-2007 excursion for around $50, is that it?
Then what is your plan for the wire to power it? <snip> That ford vacuum pump looks like its only intended to run HVAC and 4wd vac actuators.
Great catch! That Ford pump was my plan, but you are absolutely right! It's not for brake boosters. Thanks for pointing that out.
I like those Hella Universal ones - they appear to have a built in on/off switch activated when vacuum is demanded.
