I was able to pretty much finish up the fender work yesterday.
I got the bondo sanded down, put another coat on and sanded it again. It definitely could have used another coat, but looking at the rest of the car this is not needing to be a 'perfect' repair job.
So, it got a shot (ok a bunch of shots to attempt to smooth my bondoing job a little more) of primer.
More sanding of the primer.
Then I shot it with some gloss black. It seems to have turned out pretty good. Although I haven't seen it dried yet. The last step will be to hit it with a buffer. I'm not planning a clear coat, but I'm open to suggestions.
