Old 03-05-2016, 02:25 AM   #43 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
I'm thinking of a rectangular sheet with triangular cutouts to give a diamond-shaped chassis with arms that reach to the center on the sides. The plywood is available in vertical grain, the way it's used in balsa/fiberglass composites; and with choices of 1/4, 1/2 or 3/4" thickness the width might be 2-6". Wrapped in fiberglass?
Wood makes a good core for fiberglass springs, so if you add strategically oriented unidirectional tapes, you get a lot more great possibilities. However, anything resembling a swing axle usually has a very high roll center and produces bad scrub on bumps.
