Old 03-06-2016, 03:58 PM   #3 (permalink)
Striker2237
Silver Magnum - '03 Dodge Ram 1500 Laramie
90 day: 11.43 mpg (US)
I lowered the compression about a point to be able to use more boost and also like you said I picked pistons that are very detonation resistance with a design that has a much faster and more consistent flame front.
Also tried out total seal's gapless rings to eliminate blowby (for the most part).
Mostly did the work because I wanted to refine the engine a bit more, the VVT system was working a little too well (making the cam too small down low) so I adjusted the engine so it has more TQ output below 3k.
