Old 03-13-2016, 03:22 PM   #401 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Well the temps outside just haven't been that warm so no turbo compound verses single turbo ABA results yet.
I built my new nitrous setup this Saturday and its a three stage system.
1st stage is a 75 shot dry direct port to ramp up boost at a stop to launch the car at the drags.
2nd stage is a upper rpm 30 shot dry that feeds into the turbo compressor.
3rd is for FE. Its a extremely small amount of nitrous that will be used to test in combination with lean burn. I did some testing on this a couple years ago. I found out that a small amount nitrous accelerates the flame speed so I can run less ignition timing while in lean burn. This should help to lower BSFC and increase FE.
I know this will not be cost effective because the cost of the nitrous, so its more for experimentation purposes.
Pressure Gradient Force
The Positive Side of the Number Line
The Following 2 Users Say Thank You to pgfpro For This Useful Post:
Joggernot (03-14-2016), LeanMeanDSM (03-29-2016)
