For 'rule-of-thumb', substitute 'sanity check'. If you result is wildly divergent, you might double-check.
Ok. I'll check in with San Ity.
Are you seeing 83 watt-hours/mile?
Maybe just guessing the range factor in a world without air. The 330 miles guessed above is based off of rolling resistance only. No air drag included in that equation.
Edit:
I'm thinking I'd like to push the Arcimoto electric tadpole with a Vespa motor scooter converted to a one-wheel trailer.
Cool!
