Old 03-16-2016, 02:14 AM   #2643 (permalink)
shaggythegangsta
Originally Posted by MPaulHolmes View Post
Holy mackeral! A lot has happened in the last few days! I need to check in more often! I've been so busy with my job, I haven't been keeping up. Shaggy, could you tell us what the name plate says on your motor? It's a 3 phase motor? What is the kw rating? What voltage rating? What does
run-pi-test
do? does it just say the test failed? This is sort of hard to debug. There's a lot of unknowns.
Hello Paul the motor is 3 phase motor rated for 230v or 380v. I'm using the motor in 230v configuration and it has 8.4A nominal current and the power factor of 0.78.
When I run the pi test I can hear tick tick noise but the motor just remains blocked.. It does not rotates like in many videos that I have seen on thingstodo' channel during the pi test..
Would you please send me a code for pwm testing... Like driving the motor in open loop to be sure that pwm are OK?
