Old 03-19-2016, 07:14 PM   #1 (permalink)
ascendedmind
A Source for 1985 Honda CRX HF Auxiliary Float?
I cannot seem to find a replacement Auxiliary float for my 1985 Honda CRX HF with 1.5 engine.
Are you aware of any sources for new Auxiliary float replacements?
According to Honda the Part Number for the Keihin 3 barrel carburetor is:
16013-PE0-701 (Float Set)
I was able to find the primary float on ebay, but not the auxiliary float.
Is there another name for the auxiliary float?
What keywords would you use to find this part?
"The auxiliary throttle bore is much smaller than either the primary or secondary throttle bores, and is completely separate from the other two. It has its own fuel bowl, float, needle valve, air bleed, vent hose and cut-off diaphragm, idle mixture adjustment and throttle linkage adjustment (referred to by Honda as the "Lambda" adjustment). So for all practical purposes the auxiliary throttle bore is essentially a mini-carburetor within the main carburetor."
