Old 03-19-2016, 07:14 PM   #1 (permalink)
A Source for 1985 Honda CRX HF Auxiliary Float?
I cannot seem to find a replacement Auxiliary float for my 1985 Honda CRX HF with 1.5 engine.
Are you aware of any sources for new Auxiliary float replacements?
According to Honda the Part Number for the Keihin 3 barrel carburetor is:
16013-PE0-701 (Float Set)
I was able to find the primary float on ebay, but not the auxiliary float.
Is there another name for the auxiliary float?
What keywords would you use to find this part?
"The auxiliary throttle bore is much smaller than either the primary or secondary throttle bores, and is completely separate from the other two. It has its own fuel bowl, float, needle valve, air bleed, vent hose and cut-off diaphragm, idle mixture adjustment and throttle linkage adjustment (referred to by Honda as the "Lambda" adjustment). So for all practical purposes the auxiliary throttle bore is essentially a mini-carburetor within the main carburetor."
Old 03-19-2016, 08:25 PM   #2 (permalink)
Sure it's bad?
Old 03-19-2016, 09:00 PM   #3 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I saved the carb from my 1984 Civic Wagon. I don't remember the aux bore having its own bowl/float, but it's been years since I've looked at it. You want a used float or whole carb?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 03-19-2016, 09:14 PM   #4 (permalink)
Sounds like they share the same float, but that is just a guess, anyone been in one in the last few decades.
regards
mech
Old 03-19-2016, 09:41 PM   #5 (permalink)
I want to be prepared for all replacement parts as I plan on keeping this car.
