Made some progress with the GS450H gearbox. Using the DIR pin from Paul's resolver board has made a big difference. OF course then I receive some PCBs in the post today from Paul with a new resolver board and the DIR pin is broken out
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
