Old 03-26-2016, 02:56 PM   #16 (permalink)
aerohead
have any?
So, do you guys think that the all-in-one upper- and lower-grill block, fog lamp cover, and gap seal will work? Do you think that my engine will be able to keep itself cool at sunrise, or will I need to remove that section? Do you have any suggestions? Have any of you tried blocking this much at once?
The only thing I'm aware of is the IVECO 'Glider' concept 18-wheeler tractor.It has a non-porous cooling system which doesn't rely on a radiator for cooling.
http://preview.turbosquid.com/Previe...e8Original.jpg
The current active radiator shutters are a way to reduce cooling system drag as a function of engine heat flux,operating automatically.It's smart.And it allows those who worship at the alter of design to continue their aesthetic permutations ad infinitum.
Xist (03-26-2016)
