Old 03-29-2016, 01:59 PM   #403 (permalink)
LeanMeanDSM
Defeating the EPA's trap!
LeanMeanDSM's Avatar
DSM - '92 eagle talon tsi awd
Team Turbocharged!
I am looking into trying some hho when in vacuum to speed up burn speed, and I did the cap/diode mod and converted my stock ignition to plasma to help as well, with the cap/diode mod I have to increase base timing buy 5 degrees.
My lean burn is not a hole in the map but a full time always on lean burn, from startup at 0 to 4500 rpm and all vacuum till about ten psi boost, i have to start the car in normal stock mode than once warmed up i can switch to leanburn, if i try to turn on leanburn before its warmed up it does not drive very nice and misfires.
The Following 2 Users Say Thank You to LeanMeanDSM For This Useful Post:
Logic (04-01-2025), pgfpro (03-29-2016)
