Old 03-31-2016, 03:44 PM   #388 (permalink)
jackbauer
jackbauer's Avatar
it's from a GS450h. I made up a crude adapter plate from a piece of 1/2" aluminium and tapped three 1/4" bsp holes over the ports. This will allow me to use an external pump and run some more experiments.Best guess is left is the pressure port , right is return and bottom is a dipstick port. More to follow ...
Name:	2016-03-31 19.58.28-800x800.jpg
ID:	19861   Click image for larger version
Name:	2016-03-31 20.06.56-800x800.jpg
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
