If i calculate:
380V / 8,3A = 45,7ohms (resistance of coil)
so:
(120V / sqrt(2)) / 45,7ohms = 1,85A (new current with 120V)
My motor is a 2 poles, if I re-connect the series coils all in parallel, need only the middle of voltage. So the power is:
P = (2*120V) * sqrt(2) * sqrt(3/2) * 1,85A * 0,88 * 0,83
P = 562w
If run it up to 200Hz (with Paul´s controller), can give me approximately 2,2Kw.
It´s that correct?
Los que dicen que es imposible, no deberían molestar a los que lo están intentando...
