Old 04-06-2016, 12:50 AM   #54 (permalink)
Daschicken
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Originally Posted by serialk11r View Post
The thing is, on the highway your engine is at low load and that's really when lean burn will help a lot. The other situation is idling, but a real hypermiler turns off the engine :P
The issue with enrichment is that the throttle is configured so that you get a lot more load with a small press of the pedal at low rpm, and you could be inadvertently going into enrichment. It took me a while to discover that despite my best efforts I was still hitting enrichment at 80% load. I have since calculated what the mpg meter should say at the highest load it won't go rich at, and am retraining my foot to step to that way.
Increasing ignition advance isn't going to do jack, but you're right, NOx will increase. If you don't like that, you can still benefit from tuning by increasing EGR or at least knowing about the EGR valve. My wild guess is that your EGR flow rate is knock limited so you can consider modding the valve or something and adding some cooling to it.
My view on NOx is that a large diesel garbage truck or semi or street cleaner is causing way more health damage than a bunch of lean burn passenger cars. If you tune the engine to run a bit richer at high load while maintaining EGR at low load, again, miniscule NOx compared to a diesel truck.
I'm new to the whole tuning thing, previously I have worked on carbs, so I have an idea what is rich and what is lean, but my knowledge ends there. I have no experience messing with fuel injection (because it WORKS!), so forgive my ignorance. I looked at the price of a tuner, and it's $900. No thanks, too pricey.
I went out and tested what load open loop happens at, it is at 93% load, damn near full throttle. I also looked to see how long it stayed in open loop after restarting the engine, its about 8 seconds.
I also got a new best trip! 42.3 MPG! It was almost 43 mpg, but a stupid stoplight was tripped by a truck, and I had to stop. Also installed a new undertray panel, which may have helped, but I am almost certain the extra MPG was due to the fact that the car was already warmed up.
Will post about the new undertray panel and my plans after I get some sleep.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
