Old 04-07-2016, 02:35 PM   #19 (permalink)
Geofly
Geofly's Avatar
Canfly - '89 Pontiac Firefly
90 day: 57.49 mpg (US)
I still have not had time to try. But the plan is soak them in penetrating oil. Then put a braker bar on a spline drive socket. If that doesn't work then impact. If that doesn't work Cut. That's the way I usually approach seized bolts just have to be careful not to round them with step one, or your cutting. I suppose you could try an ez-out type remover for rounded nuts but they almost never work.
