Old 04-11-2016, 10:50 AM   #35 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
GGP Planning - Chap. 3: Track layout maps and TURN NUMBER ID's
Here are a couple maps of the track.
This is mostly to set you up for the Chapter 4 discussion of fine tuning your lap times in an effort to get a decent (or superlative) score in the Time-Speed-Distance aspect of this Stage of the Green Grand Prix.
Also, for anyone participating in the GGP for their first time, these should be very helpful. (HINT!) We go around clockwise.
This line map with numbered turns gives a clear view of the track. I'll refer to the turns by number later in Chapter 4, in particular Turns 1 and 11. Also, note the Start/Finish line, located between Turns 11 and 1. BE AWARE: I've seen other maps of the track where the turns are numbered differently. Turns 1-4 are always numbered consistently, the variations are in the later turns' numbers.
Our event does not use the "Inner Loop" which follows after the Back Straight. We drive straight through. We also don't drive "The Boot", Turns 6-9 in this map. That's probably a good thing for us: it has a drop of 100' and of course the climb back up.
The elevation map is helpful in that it gives you some idea of the grades in this track. The map exaggerates the grades visually, but I'm sure the elevation feet notes are correct.
Coast long and prosper.
