Old 04-12-2016, 01:35 AM   #5 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Consider direct drive motors rather than geared, because when throttled-off the direct drive will acf as a brake, which is good for a wheel chair. Geared moted will clutch out when you throttle-off, and then you coast. For a wheelchair the free automatic braking seems safer. I liked my experience with ebikes.ca... here is their motors page: Motors - Ebike Parts - Shop
Good for research for you mostly... their smallest wheel is probably the 16" one.
To control speed and torque the motor controller is your key. Also go for a 36v or 24v system... lower speeds...
What kind of range does it need to have?
skyking (04-12-2016)
