Old 04-12-2016, 01:00 PM   #3 (permalink)
FarmBoy
Battery weight
I chose this battery pack..
1. Because motor is rated for 144VDC. I wanted max performance.
2. I wanted around 100 mile range.
The ten Lead Acid traction batteries weighed 660 lbs. My 96 Lithiums weigh 422 lbs. and consume 1 cubic foot less volume. I also removed steel angle iron battery restraint frames and will use aluminum angles.
I am shopping for BMS and charger right now.
Thank you for the hint on where to post. I was surprised not to find a section for classifieds on this site.
