"...each [one] is a rod and pickle for Japan."
Mot be a localism?
It does show how it was done (in halves). Speaking of stealth and performance:
https://en.wikipedia.org/wiki/Horten_Ho_229
The H.IX was of mixed construction, with the center pod made from welded steel tubing and wing spars built from wood. The wings were made from two thin, carbon-impregnated plywood panels glued together with a charcoal and sawdust mixture.
The center section was a tube frame for the landing gear, engines and cockpit, while the outer 2/3 was like the Mosquito with added charcoal for more stealth.
