Originally Posted by MPaulHolmes
I can make changes and email them to you, but they will be untested. But if I don't change too much at at a time, it won't be so bad.
If you have the big change - the PW<512 change - done then please send that one and I'll get it loaded .. hopefully .. later tonight and do a couple of quick tests. I will need to replace my 80A breaker with a contactor, but that's the only change I should need to my setup.
If that is stable, I'll get .. hopefully .. the AC testing completed this weekend.
The rest of the changes/upgrades can wait until after the AC testing is complete.
I need to sit down and figure out where to stick a couple of LEDs - Green for powered up .. and maybe yellow for initialize is done ... and it blinks at maybe 1 Hz for OK .. MORSE CODE for errors?
