Old 04-17-2016, 12:22 AM   #7117 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
I also talked to Adam about adding more data to the log
If the data is not formatted as RTD Explorer wants to see it, it will be ignored! So I can take your AC controller code for logging data with commas between (CSV format) and print out the data both ways.
This change will likely be made shortly after the AH change ... if the AH change works.
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (04-17-2016)
