Thread: HCH1 Ecomodding
Old 04-20-2016, 06:18 PM   #17 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.53 mpg (US)
The HCH1 will not work with a normal G1 Insight grid charger without modification, because the cooling fan requires a PWM signal to turn. Today, my eBay special PWM generator came in, and I will be incorporating it into my grid charger as soon as my replacement power supply comes in. This time around, I'm using a single 500ma Mean Well LED driver, with a 100-200v range. Charging should be slightly faster now, and should work on both really cold days (higher voltage) an from a deep discharge.
http://www.amazon.com/Power-Supplies-100-200V-500mA-Supply/dp/B01BKA5B70?ie=UTF8&psc=1&redirect=true&ref_=oh_aui _detailpage_o00_s00
