Old 04-24-2016, 02:49 PM   #56 (permalink)
H-Man
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
If my transmission had 2 diff ratios and used it to reuse 4th and 5th, with a 3.1 high diff ratio and a 4.31 low diff ratio my RPM at 65 MPH would look like this:
Code:
gear     ratio            RPM
3rd      1.31*4.31      5096
4th     0.969*4.31     3770
5th     0.815*4.31     3171
4th H   0.969*3.1      2711
5th H   0.815*3.1      2280
As far as RPM goes, that 4H and 5H look pretty good, I'd be at cruising RPM at highway and freeway speeds. Right now I can hold 5th at 35 MPH and don't need to think about downshifting if I'm over 45 MPH.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
